Factory Wiring Harness
I have a question about the factory wiring for a 94 Accord EX. I am trying to connect an after market stereo but I have hit a snag in the process. On the diagram for the wiring it says there should be a blue & red wire w/ green stripe for the positive front left and right speaker respectively. I do not have these wire combinations in my car. Could someone with experience with the wiring on the factory end please help me. Thanx
buy a harness. dont splice into factory wiring. dont cut the factory harness. if you already have match the colors back up solder and heat shrink and buy a harness. they are 15 dollars. save you time and the person who has the car after you a lot of headache.
gotcha. then you understand what I was saying about saving some headache. where did you find the diagram? I will look and see if I can find another.
all the ones I find show the same color code as you see. pull the door panel on one side and see what color the wires are going into the speaker.
I found it on every site that had a diagram. The biggest problem I had is for the positve connection for the front speaker wires. The diagram says there should be a blue (left front ) and red ( right front ) wire with a green stripe, respectively, but I don't have these wires in my wiring.
I would just buy an OEM harness for your car, color match it, and save yourself and most of all the person after you the headache. Ive messed with one to many cars that had the harness cut out and its extremely ignorant and annoying for someone to do.
you can find these cars in salvage yards, remove the harness, and replace.
1994 Honda Accord Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/White
Radio Switched 12V+ Wire: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Wire: Red/Black
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: N/A
Radio Amplifier Turn On Trigger Wire: N/A
FrontSpeakers Size: 6 1/2″ Speakers
Front Speakers Location: Doors
Left Front SpeakerWire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6″ x 9″ Speakers
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
calenatar
02-12-2007 10:18 PM
