guage help
guage help
i have a 2000 accord lx and i just replaced the cluster lights to led. now the lights are changed and work but the speedometer or the tach and temp guage in the cluster work nor the digital odometer or pwr windows. i checked the fuses didnt see nothing blown and checked the plugs to make sure there pluged in and they were anyone have any help
Use a DMM to measure voltage, only way to trace your issue. You didn't get one or more of the harnesses on the cluster plugged in.
Did you disconnect battery negative? That should have been done b4 you did this. Do that now to reset the car.
Power windows are separate from the gauge, but are tied to ignition and the door switch in some cars. You shouldn't have affected that fuse though. Check each fuse by measuring voltage on both metal tabs on the top of the fuse. Voltage on one side but not the other indictes a blown fuse,
haha
no i didnt disconnect the negative but i took the cluster out and replaced a blown light now nothing works (tach,speed,fuel temp and windows) but the lights on the cluster work checked the fuses again yet they are still fine
note that you will need the 5-digit code to unlock the factory radio if it has a built-in security system (should say on the front).
i use my tripometer to keep track of gas mileage. i know how many miles i can get on a tank or partial tank.
nickmg555
04-22-2011 08:47 PM
