Hiss problems w/ high level Inputs. Please advise..
RE: Hiss problems w/ high level Inputs. Please advise..
ORIGINAL: bginvestor1
Macleod,
Unfortunately, I don't have enough 4 gauge wire to go to the trunk. [:'(]
Macleod,
Thanks for the suggestions. You said, "The 360 has a line driver in it as well and should raise the noise floor considerably."Raising the noise floor is not a good thing, you are not suggesting that the 3sixty is worse than hooking up high levels to the AMP directly, correct?
Mac: Isn't it better to have shorter speaker leads and longer RCA's than vice versa? I thought that the speaker leads are more prone to picking up noise.
So the shorter the RCA's, the less likely they are to pass by something that can induce some crud into the signal.
There is nothing much to show. I have the speakers in the stock locations althought my doors have 4 layers of Dynamat on them and my door skins have not only Dynamat but pollyfill, modelling clay and foam in them. The tweets are in the stock dash locations.
My sub is in a plain sealed box in the front of the trunk firing into the cabin.
I have my amp board mounted vertically directly behind the sub so you cant see the sub at all. When you look in the trunk you just see the amp board with the amps and processor on them and its carpeted in trunk liner.
I hate and suck at installation. I enjoy the tuning and listening. My installs are always bare minimum. Just enough to make it solid and safe. Very little creativity.
ORIGINAL: MacLeod
That Phoenix Gold would help a ton. It will turn the speaker inputs into RCA outputs and boost the signal to 11 volts max.
To clarify, would this phoenix gold unit help a head unit with low voltage RCA preoutsgain power/stability/sound quality? Obviously a new HU would probably be the best option...
Thanks
the line driver is 8volts output, capable of 11..................... this is cheaper: http://cgi.ebay.com/HUGE-PLANET-AUDI...QQcmdZViewItem
#17
Phoenix Gold is a better piece of gear - plus I stay far away from anything bought off Ebay.
And yes, a line driver will take the low voltage RCA output of say a Sony head unit and bump it up to whatever its spec'd for.
denierlexiese
08-07-2015 01:08 PM
ikethegreat
11-19-2007 04:07 PM
