Improving audio on 2007 Accord SE (4-cyl)
New to the forum and have a quick question - I've got the in-dash 6-disc changer (120 watts total). All I'm wanting to do at this point is to get some better sounding speakers. I'm guessing that the max wattage for each speakeris 20 watts (20X6). Would I be fine in getting speakers w/ just 40-50 RMS? Also, the sound coming from the tweeters in the dash is kind of annoying. I'd rather disconnect the tweeters (if possible), and just get a couple 2- or 3-way speakers in the door, and then a couple 2- or 3-way speakers in the back.
Questions:
What speakers do you recommend based on the above, and how do I go about disconnecting the tweeters. Do you think disconnecting the tweeters is still necessary if I get 3-ways in the door? Also, what's the best way to get to the speakers in the door? I'd rather not remove the door panel. THanks in advance!!!!
Gus
Questions:
Gus
RE: Improving audio on 2007 Accord SE (4-Cly)
The power handling ability isn't as importantas the sensitivity. Speakers with higher sensitivity will sound better with low power. There's a zillion brands that will work. You can start at Crutchfield.com to see what fits your car (from their stock anyway). I believe the tweets are tied into the front speakers but not positive. The only way to install new speakers in the doors is to remove the panels and they will likelyrequireadapters or a little fabricationto work. I suggest two way speakers unless you are going to amplify them.
Here's how mine is set up. I did the speaker replacement a while back and the rest recently. Let me clarify that......I PAID to have it all done, I'm not capable of doing it.
https://www.hondaaccordforum.com/Amp...m_52021/tm.htm
RE: Improving audio on 2007 Accord SE (4-cyl)
ORIGINAL: gusturner
Questions:
And these would be more for a budget. -> http://www.polkaudio.com/caraudio/products/db521/
Thanks for your tips above. I ended up going w/ Boston Acoustics S65 2-ways in the door. I let an installer put them in for me, & he ended up having to add a spacer so that the back of the speakers wouldn’t get in the way of the window when it rolls down.
After listening to them for a few days, it was far too ‘bright’ in the front, now having 4 tweeters. So, yesterday morning I disconnected the tweeters in the dash (which took all of 2 minutes), and the sound is great. Sure, it could be better w/ a small amp, but I can definitely live without that. The rear 6X9 factory speakers are actually pretty decent and provide a surprisingly satisfactory amount of bass, all things considered. And since I do most of my driving from the front seat, I think I can live for quite some time without upgrading the rear speakers.
Again, thanks for taking your time to offer your tips to the newbie!
Take care…
Take care…
Not to hijack this thread, but I wanted to add soomething about the rear deck speakers, based on my recent experience.
Just added Boss Blade Extreme BLX69 to the back of the 2007 VP. Specs: 6x9, 3 way, 95 db 1w@1m. Had to trim the underside of the grill to fit the much thicker speaker flange. Immediately, the front door speakers sound inadequate, so I'm looking at the Infinity 6012i/6022i series. Their mounting depth looks to be a good half inch LESS than the above mentioned Boston Acoustics S65 drivers. Also, Crutchfield will provide adapters free.
All of your comments above have been helpful.
When I installed my speakers in my 06 I came across something I never saw mentioned here on the forums. The stock front speakers are 6.5" BUT the hole in the door is not big enough for a regular 6.5" speaker to fit. So to get aftermarket speakers in there your going to have to cut metal, so I hope you know how to use a jig saw. Also the depth is exactly 2", so any speaker you get deeper then 2" your going to need a spacer. You can fit a 2" maybe 2 1/5" spacer if necessary, I have my JLs with a 1/4" spacer and there is about 2" to 3" of space between the front of speaker and the door panel.
So if your not comfortable using a jig saw, then maybe you have your speakers installed by someone. Just what ever you do don't mount the speaker in your door panel. I have seen that done, the resonance of plastic is defiantly in the range of the speaker so expect some serious rattling. Don't spend money on quality speakers to mount them incorrectly, you will severely degrade the sound quality.
akalmand
04-24-2012 07:39 PM
hiphophead
06-30-2011 08:59 AM
