Installing Wiring for amp
Old 06-08-2009 | 09:05 AM
zann121's Avatar
Default Installing Wiring for amp
Hi i have an 1998 Honda accord SEDAN. i want to hook up the wiring from the battery to the amp but i just cant seem to get the right place to make the hole on the firewall. can you please tell me where exactly i should make the hole or if there is a existing hole i can put it through, if anyone has an pic. itll be really helpful. thanks.
Old 06-08-2009 | 11:35 AM
I don't know, but I'll move this to Audio/Vis where you're more likely to get the right answer.
Old 06-08-2009 | 12:50 PM
finch13's Avatar
If you find the intake manifold, there is a grommet behind and below it on the firewall. The wire will come through just above the gas pedal inside. It's just a blank plastic plug.
tayjonichole
01-05-2014 01:00 PM
drumdoctor
01-16-2012 10:53 AM
cowsgonemadd3
04-25-2010 11:01 AM
tru3_k177
02-24-2009 02:14 PM
Jahsaccordcoupe
11-14-2007 11:56 AM
