JL or Orion sub?
what's the budget? what are the goals?
JL amps have handy features for integrating with OEM systems. you need a remote turn-on if the amp you buy doesn't have an auto turn-on circuit (JL slash series does).
JL is great, but pricey. Orion seems to be making a come back, but i'm not sure i'd run them in my car.
what is your goal? good music? lots of bass? note that the rear deck 6x9's will distort with a sub in the trunk pressurizing them.
choose the sub you want, then choose voice coils based on the amp power you want and the amp budget you have. dual 4 ohm coils is popular, then you want an amp giving you desired power at 2 ohms. Zapco has some nice amps. Hertz/Audison does as well.
What makes you look to only JL or Orion for a sub? are they sold locally? I like combining amp mfr with the sub mfr since you know R&D has gone into the pairing. A call to the sub mfr tech support can usually get you insight as to the amp they recommend and tested the sub with.
