Kicker Sub
Old 12-04-2008 | 01:24 AM
AccordLXMaster's Avatar
Default RE: Kicker Sub
ohhh that might be my problem..i set it to 30...i thought that the low pass meant "nothing higher than"...i see now it means "nothing lower than"
  #152
Old 12-04-2008 | 01:31 AM
t00fatt's Avatar
No low pass means cut out above. Think of it like it only allows the lows to pass, low pass. Make sure your switch is set to anything that resembles low, or bass. Then the **** that starts at 30hz is the low pass **** for sure. If your low pass is set to 30hz and your running a ported box you may be hearing your sub bottom out...
  #153
Old 12-04-2008 | 01:35 AM
so dont tune my sub down that low?.....and how will i know if my sub is bottoming out??..how does that sound..and as for my High pass...what do i tune that to?
  #154
Old 12-04-2008 | 02:02 AM
t00fatt's Avatar
High pass is only for speakers. When you make a ported box it's tuned to a frequency, go below the frequency and the driver becomes unstable. Most ported boxes are above 34hz. If your low pass is set so low and you play a song that has ridiculously low frequencies your sub can bottom out. You can only hear down to 28hz, 34hz is LOW. If it was bottoming it out it would have busted by now, it would be a loud clack or a pop.
EDIT: BTW 1hz is one time a second, so 30hz means it is only reciprocating 30 time a second. I know its irrelevant but a lot of people don't actually know that. I'm always fascinated just by thinking about it [sm=nerd.gif]
  #155
Old 12-04-2008 | 02:22 AM
alright thnx...off topic kinda....can u check out my other post about a CAI because i reall tneed info on that
as far as this..i got it...thx
  #156
Old 12-04-2008 | 02:35 AM
t00fatt's Avatar
If its not a 2 stroke piston port engine I don't know jack about it. CAI isn't a tough install though, never done one but seems pretty straight forward.
whiskeywarden
08-02-2013 10:50 PM
mrinno
23
09-20-2008 12:26 AM
mrwigglezdj
07-11-2008 12:03 AM
ziggy!talon
05-15-2008 01:53 PM
mrinno
15
01-15-2008 01:00 AM
