Radio code - Only accepts 4 numbers...
If you have the Nav/radio you will have 2 codes. 1 to unlock the radio and one to unlock the Navi. You will have to go to the dealership to get them.
Has this been your car since new. I have the 07 with Navi. And the system is different from when I purchased the car in 06 due to a failure. Of course I fixed it myself and in turn the codes changed which Honda would have no knowledge of. They must pull it to be able to get the codes (only if your system has been changed. If not then they should be able to pull it by VIN).
#18
"Press and hold the 1 and 6 radio preset buttons, and turn ON the device" is only used to retrieve the serial number. You still need to contact Honda or the dealership for the radio code.
