radio research
radio research
so i have looked around at a bunch of places and have found out that it is the factory radio unit itself that is causing this. the actual radio where the harness plugs in. apparently some people know how to fix it because they are "selling" it on ebay if you ship them the radio they will fix it... I was curious if anyone on here actually knows how to fix it... I would greatly appreciate it. Thanks!!!
RE: radio research
on the inside of the factory radio itself, there is a component that fails which causes the screen to go blank and the courtsey lights to not go on... people on ebay will take your head unit and fix it for you, or you can get a new unit from honda... i was just wondering is anyone knew exactly what needs to be fixed on the inside of the factory unit....
RE: radio research
if you feel comfortable dis-assembling your radio I'd assume it's just a bulb but you'd have to remove the casing and take the whole thing apart to fix it.... I don't know which component is the culprit but if you can take it apart I'm sure you could figure it out with a multi-meter
RE: radio research
YEAH I AM COMFORTABLE TAKING IT APART I'M AN ELECTRIAL ENGINEER BUT I JUST DONT KNOW WHAT IT IS I AM LOOKING FOR TO BE HONEST I WAS JUST CURIOUS IF SOMEONE HAD DONE THIS BEFORE... THERE IS NO BULB IN THE RADIO UNIT ITSELF.. WHEN YOU TAKE THE CENTER CONSOLE APART YOU THEN TAKE THE RADIO OFF OF IT WITH 2 MORE SCREWS... BUT THANKS FOR THE HELP I APPRECIATE IT. I'LL POST UP ANY FINDINGS THAT I MAKE ... IF ANYONE ELSE HAS ANY IDEAS OR HELPFUL INFORMATIONS IT WOULD BE GREAT.. THANKS
RE: radio research
I hate caps lock.... *L* anyway, didn't realize you were electronically educated since most people aren't... I haven't done this repair personally but if you do it please let us know how it's done/what it is. Thanks
1a9c9c9ord
12-12-2007 01:04 AM
