rear speaker not working
While I was driving home the other day, I noticed my speakers sounded different. The left rear speaker only plays really high notes sometimes and other times it is normal and plays the base with the highs. I tried to see if it was a connection problem but everything was connected properly from what I could tell. Whats more, is the speaker will actually stop playing the base when I am driving and start right back up playing base in a couple minutes and then stop again? I have no idea what this could be. Also I have these speakers along with my two front door speakers wired to a 4 channel amp. Any help is appreciated.
RE: rear speaker not working
If your HU has a reset buttontry that. I have had a similar problem which was fixed with the reset button ona Pioneer HU but no amps were involved. Might want to try messing with the gains on the amps and disconnecting and reconnecting amp and speaker wires.
Your speaker wires could be stripped and grounding out on the chassis somewhere.
Try wiring the speaker straight to the amp (not running it under any carpet or anything) and see if it plays right. If so then you may need to run new wires.
drewk2
05-30-2008 11:21 PM
