Reducing Bass in speakers
I am wondering if its possible to reduce the bass in speakers, w/o lowering the bass in subwoofers? For example, when I lower the bass through my radio, all the bass goes down. If my speakers did not have bass, would that sound ok since I have subs. Any help =
I forget the amp I have, I will look later, but its a 1,000watt max Audiobahn amp. Arg.
Also, what are these and what do they do? Would this help w/ my problem.
http://www.audio-warehouse.com/web/mdl/402VL/detail.asp
Sorry for the noob questions
RE: Reducing Bass in speakers
Hmmm...you linked to an equalizer. I have never hooked one up in a car system, but assuming its the same as home, it would essentially have the same impact as turning the bass down, if all speakers (subs and woofers) are hooked up to it. It would just give you a bunch more options. Any mid-high end deck has this kind of stuff internal, though probably not as in-depth.
Now, if you were to only hook up the EQ to the woofers, then you could control them separately.
Alternatively, you may have settings on your amp for hi-pass and lo-pass filters. Applying the hi-pass filter at a certian frequency would pull or eliminate bass from the woofers. See this link.
http://en.wikipedia.org/wiki/High-pass_filter
When I had a setup, I had one 12" sub and 4 woofers. Half the amp drove the sub, the other half drove the woofers. I applied the hi-pass filter to the woofers, and just controlled the bass by adjusting the gain on the side of the amp that drove the sub. Unfortunately, it was not by remote, so I didnt change it that often.
I would recomend several things...first of all, do you have an aftermarket deck? If so most aftermarket decks have a seperate bass control (like the one that smaglik was talking about) but instead of the the amp it controls the amp throught the deck. This would be the simplest way...by doing this you could turn down the bass, which would effect the sub, but then you can turn up the sub through the bass control (different companies call this different things). The other option would be to add a high-pass filter to each of the speaker wires between your deck and the speakers. These can be purchased at a predetermined frequency. Here is a link describing what they do...http://en.wikipedia.org/wiki/High-pass_filter The link that I followed (original post) would effect different frequencies but not in the way your looking for. Most mid-level and higher speakes that are 2-way or 3-way usually come with a crossover, which is better then a high-pass filter becaue they can be adjusted to match what you want and are designed for the specific speakers that they were purchased with. Hope this helps you out.
Thanks for the info so far guys! I will def. check into those things. As for your suggestion of turning the bass down (yes, I have an aftermarket deck, sry, forgot to mention that) and turning it up on the amp itself I have not tried that. Would doing that make the amp working harder? I usually just leave the bass level 3/4 thinking that it will help extend the life of the amp and my alternator by causing less draw.
The gain on the amp isnt a volume control. Its sole purpose is to match the input signal of the amp with the output signal of the HU. That way, when the HU is at 50% volume, the amp is at 50%. If say you had the gain set too high, the amp could be at 110% when the HU is at 50%. That would cause the amp to clip at which point the amp will send out a horribly distorted signal at double or more the amps rated power. This huge power surge can fry a speaker really quick.
The gain on the amp shouldnt be above the noon position.
As for the bass boost, it doesnt increase all the bass. All it does is raise the level of a certain frequency like say 40 Hz by 6-12 db. This isnt very good either as it causes a response hump and can make the sub sound one note'ish.
The best thing to do is to buy either an EQ or a electronic crossover. A x-over will let you pick cut off points for all your speakers a lot easier and give you a lot more flexibility.
Audiocontrol makes great pieces.
http://www.mobileaudiocontrol.com/de...51&l1=5251
So should I just set all my controls on my amp ar 50%?
Sorry, all of this seems like a foreign language to me!!!
So what would be the cheapest way to reduce the bass and the easiest way?
If I were to buy an equalizer, would this go right below my afternmarket radio, and do you know of a super cheap but quality one? Also, how is it to install? I really dont want to spend much more on my audio @ all.
Oh, forgot to mention my speakers are not being powered by my amp.
Thanks again guys for putting up w/ this! Im not all that great w/ this type of audio stuff!
Basically all you would be able to do is reduce the bass on the eq on the deck, which deck do you have? the model number, because you may have crossover controls for specifically for your speakers that dont directly effect the amp output, and just to verify youre wanting to reduce the bass from your indoor speakers/ backdeck speakers, correct?
My deck is the Aiwa CDC-X144.
And yes thats correct, I just want to stop or reduce the bass from the speakers and make it all come from the subwoofers. And would this sound okay?
Also, the amp is only powering my two subwoofers.
