small problem
Old 05-10-2009 | 11:44 PM
christian2000accord's Avatar
I pulled out each individual one on the driver and passenger side fuse boxes using the fuse pullers from the engine fuse box and I couldn't find a blown one. It wouldn't be one of the fuses in the engine fuse box would it be?
Old 05-10-2009 | 11:49 PM
t00fatt's Avatar
It might be, I would check it. Although you could just try insulating the wire, then turn the ACC on to see if it's working. Just be sure not to turn the key before then, because if it is a circuit breaker it will take a minute before it cools and resets itself. If it is still out, then check the other fuses. I'm sure you could get better helps from someone other than me, but this is all I got.
Old 05-10-2009 | 11:54 PM
ok thanks for all the advice I'll give it a try tomorrow. If this doesn't work I'll take it to someone to have it looked at but dude youve been alot of help thanks again
Old 05-10-2009 | 11:56 PM
t00fatt's Avatar
No problem man I know how it feels to be lost and overwhelmed.
Old 05-11-2009 | 02:35 PM
ok so i went behind my HU today and i found the orange wire labeled "illumination/dash light" bare with no insulation on the end. also i went in my engine fuse box and found no fuse at all on the "dimmer relay"?
Old 05-11-2009 | 05:02 PM
t00fatt's Avatar
Just another guess here, I'm really not the best one to help with this but... Do you have a dimmer control ****? If not then that's prolly why there is not fuse there. You could try putting the rated fuse on the diagram, won't hurt anything but I doubt will fix your problem.
  #17
Old 05-11-2009 | 08:12 PM
yep your right about that i dont have a dimmer control so thats why... i insulated the end of the wire that was bare and marked "illumination/dash light" and checked all the fuses visually and they all look ok, but its not fixed yet... any steps im missing or next steps i need to take??
  #18
Old 05-11-2009 | 10:47 PM
t00fatt's Avatar
Honestly can't think of anything else, but that really doesn't mean much. This is really out of my area, my advice would be to post in the general tech forum, or head over to the 6th gen forums, maybe those guys can point you in the right direction. I wouldn' take it to someone, I'm sure you can figure it out and fix on your own. But if you get desperate I'm sure most any good shop will figure it out pretty quick.
SLIPKANOT
02-02-2013 12:47 PM
NaughtiAngel
10-11-2010 01:42 AM
love2learn
03-02-2008 12:35 PM
cj_trap_shooter
03-22-2007 03:58 PM
isuboy
07-12-2006 12:31 AM
