subwoofer questions.
#25
RE: subwoofer questions.
OHHH I just got what your saying, surprising while vaping. You forgot the most important thing, the speed at which that rod and weigh move up and down, which is the frequency. Hertz translate to how many times per second. So when you move that beam up and down at it's resonate frequency ( everything has a different resonate frequency, basically what determines the resonate frequency is a ratio between density and stiffness. The denser the lower, the stiffer the higher) it will bend and move as much as physically possible. Which is resonance the frequency which will make something oscillate the most. I'm pretty stoned so I hope that made sense.
#29
Resonant frequency is when a wave (sound, tide, engine RPM, etc.) is reflected within the object and crosses the following wave in phase so that they build on each other for a split second. Now, consider this happening at the speed of sound. The built waves split apart, but are reflected back again. Now they cross a third freshly generated wave, all in phase ..... so the wave amplitude is trippled ...... depending on the resonant frequency, mass of the system, type of wave generated and decay rate of these waves, this resonance can become several thousand times as strong as the original wave.
