V.I.Q. Needing Answers ASAP
quick question for kicker L5 12" in ported box
my current amp?? the mono 1000w max California....or pioneer 760w?? nor exactly sure what model but based off a good guess which would be better?? in the long run...really in a few days ill have 2 L5s in a ported box so should i stick with mine or go ahead and get the pioneer amp so ill have more power for both of them??
I'm not sure how I can make it any clearer, but I'll give it a shot. The amp you have now is a good entry level amp and is rated true at 1000w. Trading that amp for the other amp is pointless. Not only is rated for less, but it's a pioneer, and pioneer amps are not all that great. Now if you want to run two L7s, then yes I would get that amp(if the price is right, and you can't afford something better) and run a sub off each amp. Running two L7s off one of those amps will be quieter, I don't know how many times I've got to tell you that, but this isn't the first or even second time. If you want another sub your going to have to double the power or at least get close, if not it won't be as loud and sound much worse. Under powering an L7 is going to really make it sound muddy and weak, even if there are 10 of them.
calm down dang your talking about L7...im talking about L5...lol...and im also talkin about having the 760w right now an then when i get the second L5 then getting a slightly higher rated amp...calm down...lol..u had me all mixed up and my amp is not true rated at 1000w its rated 500w rms at 2ohm...so yea...but u dont have to apoligize cuz things get misunderstood all the time...but yea i never winded up trading him i just traded another guy something for a probox so my L5 HIIIIIITTTTTTTTTTSSSSSSSSS..LOL
Doesn't matter what sub it is, X amount of power to a single driver capable of handling that power will sound better and can be louder and usually is than two of the same drivers. Hooking both subs up temporarily will only decrease your SQ and probably your output. A Probox isn't going to sound any better than a properly built box. If you were to find out the specs that are best for an L5 you would actually bring out the best for your sub, especially in a ported box. A ported box really should be tuned to your specific driver and sound your looking for. So don't put too much emphasize on marketing.
#17
Also Pioneer's amps are no better than their speakers. I don't think they are too underrated, but I know they can't really cleanly put out what they say they can. Macleod has said your amp is a good amp, I'm not familiar with it, but I would take his word for it. Numbers are just that, numbers. Not that I think your amp is overrated, but will definitely put out a clean 500w
#18
well no sir actually my box is 3.0 cu ft and it is ported plus its a probox...in that order not the other way around...the guy didnt no shyt about cu ft i asked him what its tuned to and he said an L7...lmao!!!....so i measured it myself multiplied the results and divded by 1728 if im not mistakin and got my cu ft....3.0 exactly which is the maximum amount for a kicker L5 06 model 12" in a ported enclosure....trust me...ive done my research!!..lol...and as for the amps..ok thats good info that way i can steer clear of those...and this is wat u have to understand...i figure get by for now then upgrade later rather than save up now have nothing until later...only with car audio tho...
#19
now as far as what the box is tuned to...in hz im not positive...but i know the other kicker box i had was 2.9 cu ft and its a custom kicker market box...so im good on space...just not 100 on actual hz tuning
#20
EDIT: And I'm not a big fan of those kicker boxes, I knew this kid with two L7s and would blow a panel off the box every couple of weeks, and just because they are made form kicker doesn't mean they are tuned to that sweet spot. I found out my sweet spot from someone who was competing with a CVX.
