will it just put a lil bit of power to it or whathigh output plug on your amp?
read my signature to see what i got but i got this high output plug on my amp with wires hangin out the end
it almost looks like its too hook up to my back speakers
but if i put 1500 wats rms into some lil *** 5 1/4's ill blow them to pieces
what is that for
what is that for
RE: will it just put a lil bit of power to it or whathigh output plug on your amp?
Never heard of a high output.
If I had to guess, Id say its for HIGH LEVEL INUTS which are speaker level inputs.
If say you dont have a CD player with RCA outputs, you can run the speaker wires from the speaker outputs of your CD player to the high level inputs of the amp and they will be the inputs.
There is no "high level" output except of the speaker output, which should be marked as "Speakers". You must be reading it wrong or something, but those are high level (Speaker Level) inputs. The only outputs on the amp are for the speakers, and possibly low level RCA outputs (if your amp has them).
ORIGINAL: t00fatt
matt073192
03-31-2010 06:55 AM
BlueByYou
09-23-2006 07:06 PM
