Yellowtop diffrent kinds?
RE: Yellowtop diffrent kinds?
ORIGINAL: MacLeod
The Yellow Top is a deep cycle battery which means you can run it down to almost dead and when you crank the engine up itll recharge to full capacity.
With a normal battery, if you run it down and then recharge it, it will not have the capacity it did before.
So the Yellow Top is perfect for using stuff with the engine off.
There are different sizes of Yellow Tops, but theyre the same type.
The Yellow Top is the deep cycle battery while the Red Top is a starter battery. They also have a marine battery.
Miran
05-15-2009 11:04 AM
clean coupe
10-09-2008 07:08 PM
