what is the largest tire on 19x8.5 45-ET wheel
Hi What is the largest tire(s) I can use with a 19x8.5 wheel with a 45 ET on a stock suspension 2013 Touring with no drop,without any rubbing issues? I have seen all the on-line tire/wheel comparator,but I need 'first hand' info. Will a 245/40/19 fit with no worries on a squared set-up on 19x8.5 wheels?Thanks,HB
What size tires are you guys running on your Canadian Touring's?HB
When you say "larger", are you asking if folks are running tires "wider" or "larger diameter"?
Sorry...I meant both,wider and larger diameter,but lower than the 55 stock offset,with no rubbing. Thanks,HB
shhhua
07-03-2010 07:44 AM
lippstuh
10-11-2008 12:57 AM
