My AC gives a foul smell: PLZ help
#21
RE: My AC gives a foul smell: PLZ help
It is inheritant Honda problem IMO my 84, 87, 98 & 2001 had the same thing. 19Accord97 is exactly right about turning off your A/C a bit before your destination just to rid off the moisture in the evap. Also when you leave the air blowing make sure it’s not set to “recirculation” air. BTW, is it really humid where you live? If that is the case you may want to turn your air control to “vent” no A/C , set the fan speed to 2-3, not the full blast and run a can of Lysol trough the intake vents under the hood in short blasts, cause it takes time for the “fog” to go though the vents… After you are done just leave the car in your garage with windows open and the next morning if it’s not too hot outside, do the hot air trick & you should be all set for at least a couple of month & if you’re going to repeat same procedure every 3-4 month you should be fine. I don’t know if battling the dealer is your cupatea, it’s just not worth it to me, especially if there is nothing they can really do to it…. But if you are fitin’ kinda guy go ferit
#23
Under the very top of your hood, above the rubber weatherstrip and below your windshield wiper arms. Just turn on your fan to the max and see where the air is getting sucked in, you'll find it very easy.
#24
oh, and do make sure that water does drain from the A/C system. Unless you shut off the A/C prior to parking you should see water drainage under the passenger side, just about where is the passengers feet are @
#25
Same problem with my 06 accord, and 90 integra. It's like the on/off thing, don't know when to expect it. Just make sure to let ur friends know when they sit in the car and you turn on the AC, could get the wrong impression especially new date..:P
#29
One time I had a foul smell coming from my A/C.
I found out that I had bad B.O. and I had the A/C on recirculation.
I was going to fix it but but decided to put up with the smell.
