Do-It-Yourself Section This section is for requests for DIY help, not for general technical advice.
DRL FIX .. by ECKHART
Old 06-24-2006 | 06:34 AM
deserthonda's Avatar
Default DRL FIX .. by ECKHART
On behalf of HAF,,, i would like to tank ECKHART. for writing up this post...I am sure it will help someone ..
FROM ECKHART...
Hi, I'm hoping you can post this great fix for a typical 92 (to 02) daytime running light fix (Might be for Canada cars only).
My symptoms were:
DRL light on all the time. Even when emergency brake was released.
When hi beams would be turned on the passenger side hi beam did not work.
Replaced all 4 bulbs and no change.
Found an article that the problem may be the DRL Relay. I followed the instructions and fixed it. It is as simple as removing the module, taking the circuit board out and re-soldering the joints.
Here is the article, with pictures:
http://www.nyx.net/~smanley/hondadrlfix/index.html
slippynuxx
08-17-2023 03:44 PM
zann121
06-23-2009 07:26 PM
eckhart
05-28-2009 06:43 PM
surajsss
09-14-2007 09:37 AM
eckhart
05-27-2006 08:40 PM
