Do-It-Yourself Section This section is for requests for DIY help, not for general technical advice.
EXT: Bumper Light Conversion (90-91)
Old 01-10-2011 | 02:18 AM
Rocketman_471's Avatar
Default EXT: Bumper Light Conversion (90-91)
I did this on my 90 LX, so it might be a little different for those who have a 92 or 93, at least that's what I've heard. Instead of using the Civic corner light sockets, like most people have done, I had a couple of tailight sockets that I wanted to use. So here's what you'll need...
2 tailight sockets
Phillips head screw driver
Wire cutters and strippers
Some butt connectors
Electrical tape/shrink wrap/soldering gun
First, you'll need to take off your bumper light, using a Phillips head screwdriver and remove the stock socket from the housing...
Next, you'll need to modify the tailight socket so that it'll fit into the bumper light housing. The tailight socket has 3 tabs that hold it into place. 2 of these tabs we'll be using, but the third tab is offset and won't fit into the housing, as seen inthis picture...
You'll want to cut this tab off, like this....
Now, it'll fit right into the housing...
Now, cut off the stock plug. You'll notice (if you have a 90-91) that there are 2 green wires and 1 black wire....
Combine the 2 green wires and connect them to the single green wire on the new plug and while you're at it, connect the black wire to the black wire on the plug...
Now it's time to remove the corner light, using the same screwdriver....
Run your wiring for the running light....
Now connect the new wire to the red wire on the new socket....
This part is kinda confusing. On my car, which I'm asuming that it's the same on the 91 as well, on the passenger side, there are 2 red positive wires and 1 black negitive wire that is used for the inside corner light. On the driver's side, however, there is only 1 positive red wire and 2 negitive black wires. Connect your new wire to one of the red wires on the passenger side and the red wire on the drivers side....
Now, at this point, you can shrink wrap or just wrap the wires with some electrical tape to finish everything up....
Now, hook everything back up and re-install the bumper and corner lights and you're all done....
I waited a couple of days to take a picture, due to a malfunction in my camera, but it was well worth it!
Old 01-12-2011 | 04:21 PM
Oh Yeah..That was worth it..good post and good job..
Dannyboi40
02-12-2013 05:21 AM
Bw0nz1ca
08-22-2012 05:15 PM
Cody_754
04-25-2012 11:40 PM
vipjdm-Justin
02-09-2011 06:02 PM
2008silverbullet
10-21-2010 04:30 PM
Quick Reply: EXT: Bumper Light Conversion (90-91)
