Do-It-Yourself Section This section is for requests for DIY help, not for general technical advice.
How to BLEED ABS Systems
Old 10-12-2021 | 06:27 AM
Brad B's Avatar
Hi. I know this is an old thread but I have a question I can't find an answer to. I have a 1995 accord ex v6 with an ABS light that is throwing code 1-8. I have the accumulator and need to replace it. I have rigid brake lines so I will need to take the whole unit out to change it. I've seen videos of people changing it without disconnecting the whole unit. When I do this and reconnect everything do I need to bleed just the ABS system or will I need to bleed the calipers as well? I feel comfortable bleeding the ABS module but not all 4 wheels.
Thanks.
Old 10-28-2021 | 03:36 PM
If it were me, I'd bleed the wheels and the ABS module. I think the wheels are easier to bleed than the ABS. Just don't let the reservoir go empty (either ABS or main brake reservoir).
Old 01-19-2022 | 02:09 AM
elinbiddle's Avatar
This was very useful thank you.
Old 03-12-2023 | 04:39 PM
Trinimd's Avatar
2001 Honda ACCORD EX 4 door V6
IM going to do the pedal pump method to bleed the brakes.
Can someone send the sequence for bleeding for this specific year?
thanks
sippy2
06-05-2012 03:01 PM
JimBlake
DIY Answers.
03-08-2010 04:45 PM
leg_of_tape
11-29-2006 04:38 AM
legionofone
04-27-2006 08:54 PM
HondaLawgik
01-31-2006 10:09 AM
