05 Accord hybrid V6 HELP!
Old 06-26-2010 | 05:46 AM
setokazyani1's Avatar
Default 05 Accord hybrid V6 HELP!
I just got this car it has 70k on it, everythings smooth its a hybrid v6 3.0 I vtec in it, satisfied but makes a weirdddddddddd sound when driving sometimes, I go up to about 30-40 n let go of the gas its like a rattling/bass sound that fills the car, then when i start slowing down around 5-15 mph it also happens...is this normal? or what can this be from?
Old 06-27-2010 | 09:01 PM
corvetteking's Avatar
The noise you are hearing is thanks to your Active Noise Canceling (ANC) system being faulty... Here is a service bulliten from honda that addresses the problem... '
Service Bulletin
2006 American Honda Motor Co., Inc. – All Rights Reserved ATB 31040 (0602)
CUSTOMER INFORMATION:
The information in this bulletin is intended for use only by skilled technicians who have the proper tools, equipment,
and training to correctly and safely maintain your vehicle. These procedures should not be attempted by “do-it-yourselfers,” and you should not assume
this bulletin applies to your vehicle, or that your vehicle has the condition described. To determine whether this information applies, contact an
authorized Honda automobile dealer.
March 24, 2006
06-005
Applies To:
2005 Accord Hybrid – JHMCN3...5C000001 thru JHMCN3...5C018163
Humming or Booming Comes From the Speakers
SYMPTOM
A loud humming or booming comes from the audio
system front speakers.
PROBABLE CAUSE
The ANC (active noise cancellation) unit is faulty.
CORRECTIVE ACTION
Replace the ANC unit and the front speakers.
PARTS INFORMATION
Active Noise Cancellation Kit
(includes the ANC unit and both front speakers)
P/N 06390-SDR-307, H/C 8355414
REPLACEMENT PARTS INFORMATION
The ANC unit is matched to the speakers, and you
must replace the speakers with the appropriate type. If
an Accord Hybrid with a replacement ANC unit returns
to your dealership at a later date needing a new front
speaker, order this replacement speaker:
Replacement Speaker for the ANC kit:
P/N 39120-SDA-A02, H/C 7773914
WARRANTY CLAIM INFORMATION
In warranty:
The normal warranty applies.
Operation Number: 0101C9
Flat Rate Time: 0.6 hour
Failed Part: P/N 06390-SDR-307
H/C 8355414
Defect Code: 03214
Symptom Code: 04211
Template ID: 06-005A
Skill Level: Repair Technician
Out of warranty:
Any repair performed after warranty
expiration may be eligible for goodwill consideration by
the District Parts and Service Manager or your Zone
Office. You must request consideration, and get a
decision, before starting work.
DIAGNOSIS
Service Advisor
Interview the customer to get as much information as
possible, and write it on the repair order. Information
such as where and when the problem occurs is vital to
the diagnosis.
Service Technician
1. Carefully remove the lens from the ceiling light.
2. Attach a 4-foot or longer jumper wire to the left
(driver’s) side terminal for the ceiling light bulb.
2 of 2
06-005
3. With an assistant, test-drive the vehicle as
described on the repair order to reproduce the
customer’s complaint. When you hear the
humming, have your assistant ground the loose
end of the jumper wire to the grounding sleeve of
the power outlet. Do not allow the jumper wire to
touch the bottom of the socket.
• If the noise goes away with the jumper wire
grounded, go to
REPAIR PROCEDURE.
• If the noise does not go away with the jumper
wire grounded, this service bulletin does not
apply. Refer to the service manual for additional
diagnostic information.
REPAIR PROCEDURE
1. Replace the ANC unit:
• Refer to page 23-81 of the 2005
06 Accord
Hybrid Service Manual, or
• Online, enter keyword
ACTIVE, then select
Active Noise Control Unit Removal/
Installation
from the list.
2. Replace the front speakers:
• Refer to page 23-78 of the service manual, or
SPEAKER, then select
Speaker Replacement
from the list.
3. Clear any DTCs with the HDS.
Old 06-28-2010 | 04:28 AM
Estimates on cost for parts/labor for all this?
Old 06-28-2010 | 09:48 AM
g22cd5's Avatar
Supper Moderator
call honda we wont know
Old 10-09-2013 | 01:13 PM
ArnieHN's Avatar
Default Bad Radio Signal Generator
You most likely have a Bad Radio Signal Generator. Your hybrid runs on 3 of the 6 cylinders at highway speeds with light throttle, You can tell by the green light on your dash. This creates the whining noise which you have described. The radio has signal generator which sends out a noise which cancels out the vibration noise.
I had mine replaced a few years ago on my 05 Accord Hybrid.
Old 10-09-2013 | 01:29 PM
The above post already addressed this over two years ago, it is more appropriately called Active Noise Cancellation (ANC).
rice81
02-27-2014 08:33 AM
Chaubot
08-14-2011 04:24 AM
mamtsberg
03-17-2010 10:15 PM
newbieny
10-22-2009 06:17 PM
askingfornary
06-16-2007 08:37 PM
