1990 accord throttle issues?
Old 03-21-2012 | 11:11 PM
vinceaccord's Avatar
Default 1990 accord throttle issues?
At operating temperature only, as i half throttle the pedal or in that range, my engine is severly impeaded. although, if i floor it it runs properly. this problem seems to occur every drive now. i have replaced the coil, plugs, wires etc. aswell as the fuel pressure regulator. i know the fuel pump is working from tests me and my buddy have done (hes a mechanic). ignition timing was also done and didnt change my problem. fuel filter was replaced about 8 months ago. my car is at 199580km. please help me with any ideas to get it to 200k in top working order. thanks
Old 03-23-2012 | 08:20 PM
bairdandrew77's Avatar
Make sure the throttle cable is adjusted well. And make sure all the hoses are connected with no leaks. Probably not your problem, but it never hurts to check!
Old 03-23-2012 | 09:01 PM
Problem description suggests lean stumble due to partially blocked EGR ports. As you partially apply throttle the EGR remains open and too much EG gets pushed into 1-2 cylinders leading to over lean mixture and stumbling. This was a problem for quiite a few years including the 90 Accord.
Check DIY forums for help. If you can't find anything PM your email address and I'll forward a PDF (too large to post).
Old 07-09-2012 | 06:10 PM
Ryeguy's Avatar
This seems to be what my accord is doing as well. Did you get your problem fixed?
knotty226
07-05-2013 11:04 AM
alex007
07-16-2012 09:37 PM
Al_S
06-26-2010 09:17 PM
Mstrmonkyman
12-15-2009 05:54 PM
sassyboo2
10-30-2006 02:54 AM
