1998 Honda Accord 4cly Engine Beef up
I Have a 1998 Honda Accord 4cly 2.3 VTEC i have a custom cold air intake with K&N Filter on it,
X-Force Stainless Steel Extractors an 2 1/4 inch exhaust system, but i still want more grunt, but i dont
want to go turbo because of the cost of the kit from turbonetics, other than that is their any other ideas?
I cant seem to find anything From Powerchip, Any Ideas anyone???
RE: 1998 Honda Accord 4cly Engine Beef up
You can build your own turbo kit pretty cheap, you just have to get all the parts. You should be able to get it for about $1000-$1200, or cheaper. Look around ebay or you could probably put a cam in it. I heard any power chips are not very good.
There aren't any real power chips for yor vehicle. You could port and polish the head, get a cam regrind, etc. P&P can be done locally with good race shops near you for approx. $1k and www.webcamshafts.com will regrind a cam for you for less than $400. Once you start diggin in the engine (pistons, rings, etc.)..if your not doing your on work the cost will damn near double. And learning to E-shop parts is a good skill to acquire now, once you can do that you can build a better kit for less than the Turbonetics. I'd rather get the Drag Gen IV kit anyway since the fuel system is a lot easily upgraded and it's cheaper.
