2003 Honda Accord V6 coupe - where to start?
Okay so I have my 2003 Honda Accord V6 coupe. It has 115,000 miles on it, leather interior, after market rims, and I got it for a little over 5k.
Anyway, where do I start? I wanna give it as big of a performance boosts I can with a little over $1,000. I am a beginner with cars, but my friend is a mechanic, so I just wanna get a basis of what I should ask him to do. I have heard about turbo charging, would that be a possibility? What would I have to replace?
I'd start by changing your timing belt, spark plugs, new fuel injectors, and fuel filter if you havent already done so. The first thing that i would do is get a set of camshafts from the 3rd gen TL-S(2004 - 2007). These are interchangeable with ours, and a cold air intake system w/ a bypass valve or short ram system w/ a heat-shield, intake spacer, and a j pipe and you will see a huge difference on the performance. All this plus labor if you don't know how to install it yourself should be running you around 1k or a little bit more.
gasface11
07-11-2012 12:33 PM
Sheryl S
09-04-2009 10:32 AM
