2003 random misfire
2003 random misfire
NEED HELP !!
Wife drove her 2003 honda accord v-6 to work everything was fine. Went to leave 8 hours later and check engine was on and car was running bad (missing ). Borrowed a code reader and it shows all cylinders are misfiring and random misfire.
Car has 140k and has been well maintained, timing belt and w/pn done at 110k. Plugs also done then.
Any ideas will help.
What codes were presented? P030X?. Anything else?
A failure in COP would be noted by one cylinder missing. All or most COP failure would prevent starting. Random miss is usually something w/ fuel or air.
What plugs were installed? OEM or other?
I would double check the plugs. I had a problem on another car like that. Did a full tune up. At the time I did that used sea foam in the intake/oil/gas. Ran just fine for about a month then got so clogged up with deposits being removed that it would not run. Replaced plugs again and oil change and good to go.
