2007 Accord EX Coupe, 4 cyl., Performance Upgrades
Old 06-06-2010 | 07:24 PM
Mexicali4tacos's Avatar
Default 2007 Accord EX Coupe, 4 cyl., Performance Upgrades
Discuss.
Old 06-22-2010 | 08:58 PM
Al_S's Avatar
Originally Posted by Mexicali4tacos
Hi,
I purchased a Honda Accord EX Coupe, 4 cyl. earlier this year and was interested in doing some internal performance upgrades. I'm not a fast driver, not really into the racing culture, I just like to know that the capability/ performance is there in case I have to occasionally 'speed up'.
I don't really know where to start, and wanting to ask around in this forum for advice. Aside from installing a better engine, what can I upgrade/ install that may improve the performance of the car? I'm not looking to install a turbo/ nitrous, etc. etc., just simple modifications similar to installing an intake and a better exhaust.
I appreciate any comments you may have on the matter, thank you.
Mexicali4tacos
Try http://www.driveaccord.net/forums/index.php and post your question there. I am a recent Accord EX owner and have the same goals.
Good hunting.
Old 06-23-2010 | 08:26 AM
g22cd5's Avatar
Supper Moderator
depends on how much money you wanna drop on mods. Get back with us on that and we can help you.
Old 06-23-2010 | 07:39 PM
Al_S's Avatar
Hi,
I would like to get the discussion started with that. As I mentioned, I had just purchased a 2010 Accord EX with the I4 K24Z3 engine. My 2006 I4 seems like a V6 compared to this new car, so I want to know what I can do. I was seeing posts related to CAIs and wondered if they are legal for my engine in NY. My engine is a PZEV so I guess that means it's CA smog legal - not sure. If I get one anyway, does that mean I will not pass emissions inspection? Do I have to change to the air intake box prior? The exhaust is not something I am likely to change if I can get away with it. Besides I read that for 2010 it is more advanced than prior years and I'm not going to mess with it. I don't have enough testimonials read as far as chipped ECU's go so I'm reluctant to do that too.
I guess my choices are few to none for improvements "for now". I want to see what becomes available in the coming months or the next couple of years.
Question: What's the word on break-in? The dealer says there is no break-in oil used for this vehicle and want hear what others have said. Because of the performance gap, I find myself pushing the 2010 a bit more than I should. No redline but once in a while approaching 5k on the tach.
Thanks for any advice
Old 06-23-2010 | 08:42 PM
corvetteking's Avatar
The factory fill engine oil has molybdenum (that’s “moly” for short), a special lubricant applied by the factory to critical engine components during assembly. Generally, Honda recommends the factory fill engine oil remain in the engine until the first scheduled maintenance interval.
The break in period they speak of, is the time when the piston rings seal, nowadays this is what the break in is all about in new engines...
Proper break in procedures differ from everyone you ask... Some will say take it easy, some will say give it hell...
The rule of thumb though is to vary the engine rpms with a load on the engine... This can be heavy to mid heavy acceleration through the rpm range and deceleration...
This should be done untill at least 3 to 500 miles, although most of the engine break in are done in the first 20 minutes of driving... Then from 500 to 1500 miles while still varying rpms, do 5-10 WOT pulls spread out through the milage, then after that give her hell...
Old 06-23-2010 | 08:48 PM
The problem with easy break in is the honed crosshatch pattern in the cylinder bore acts like a file to allow the rings to wear. The rings quickly wear down the "peaks" of this roughness, regardless of how hard the engine is run. There's a very small window of opportunity to get the rings to seal really well ... the first 20 miles !! If the rings aren't forced against the walls soon enough, they'll use up the roughness before they fully seat. Once that happens there is no solution but to re hone the cylinders, install new rings and start over again.
Old 06-24-2010 | 12:40 PM
Al_S's Avatar
What does that mean "...soon enough"? Please explain in the context of the thread.
Thanks
Old 06-25-2010 | 01:25 AM
""If the rings aren't forced against the walls "soon enough"(usually the first 20 miles), they'll use up the roughness before they fully seat. Once that happens there is no solution but to re-hone the cylinders, install new rings and start over again...""
9 out of 10 Times you will have nothing to worry about... Most of the time the motor is already broken in by the time you get in it to drive it home... This is just one opinion on proper break in...Sorry if this freaked you out, was just trying to explain "break in" for you as you asked... If the motor has not broken in properly, you will know it after the first 1500 miles... Excessive blow by or a decrease in gas milage
will let you know... Your vehicle should be under warranty, so if something does go wrong, you are worry free... Thanks for readingl .......
Old 06-26-2010 | 11:05 AM
Al_S's Avatar
Thanks for the insight. So based on what you commented on, all moving surfaces are properly "mated" I think though hindsight tells me that I should still not push the RPMs until the first oil change. What is your opinion?
Old 06-26-2010 | 02:55 PM
Default ECU performance upgrade?
Discuss.
chevelle540
04-25-2013 06:00 PM
dmadigan
10-13-2011 01:17 PM
Mexicali4tacos
06-17-2010 01:06 AM
keycar117
01-29-2008 03:39 PM
MacLeod
02-18-2007 03:29 PM
