88 Accord Aftermarket Camshaft Replacement
Old 04-16-2009 | 11:31 PM
88lxaccord3152's Avatar
Post 88 Accord Aftermarket Camshaft Replacement
I want to replace my stock cam with an aftermarket cam. I am wanting it to sound like those cameros that idle different. What kind of cam would I need to get and what brand would be the best? About how much would it cost to have someone replace it for me?
Old 04-25-2009 | 12:30 PM
streetlimitz89's Avatar
to sound like a camaro ... just take 1 plug wire off and it wil have tht idle like iit all they are is just a larger cam lobe causing a rough idle
Old 05-04-2009 | 09:28 PM
masudkarim
Default 88 Accord Aftermarket Camshaft Replacement
Camshaft drives, whether gears, belts or chains are also able to even out wear,
... Aftermarket timing belts may be used to alter engine performance. ... Gates
- Timing Belt Replacement Guide with illustration of V6 timing ... When changing
the timing belt on a 90 Honda Accord do you have to get the .
bossie
03-30-2021 12:17 AM
CR123
03-05-2013 11:28 AM
kris_loehr
12-19-2008 08:20 PM
deserthonda
05-12-2006 01:12 AM
