90ex questions
Old 03-31-2007 | 01:25 AM
playaman's Avatar
Default 90ex questions
how do i extend the life of my boot(5spd), and what rpms should I be shifting on for best acceleration, and should i put in synthetic oil?(220k k/m)
Thanks
Old 03-31-2007 | 05:23 AM
deserthonda's Avatar
Default RE: 90ex questions
ORIGINAL: playaman
Thanks
I would have to assume you mean cv ( axle ) boot ?? if so you might want to spray it periodically with some wd-40 or any othr oil base chemical to keep them moist and keep them from drying out and cracking and eventually ripping .
As for shifting i never look at rpm i shift by feel .. so cannot give you an answer on that one
If you have the money use syntetic oil ,, if not any major brands will do ...5w-20,, 10w-30 .. the key is to change oil AND filter every 3- 3,500 miles ..if you use syntetic change it every 5000 miles
Old 03-31-2007 | 08:56 AM
playaman's Avatar
Thanks,also i noticed a clicking noise from the engine, Could that possibly be the power steering pump? Its a high pitched kind of loud clicking noise, what could that be?
Old 04-01-2007 | 01:43 AM
Shadow1992's Avatar
When do you hear the clicking?
Old 04-02-2007 | 01:55 AM
playaman's Avatar
on engine idle, basically when the engine is runnin even on higher rpms.
klrspz
05-03-2012 07:29 PM
maxst2
03-17-2005 02:44 AM
poff1986
12-11-2004 10:36 AM
sviana
12-07-2004 04:09 PM
maxst2
11-23-2004 01:02 AM
