91 Accord SE all brakes locked up
Here's one I cant find an answer on anywhere on the internet! I feel like I have the only car with this issue! I bought a cheap 91 accord se, all the brakes are locked up, they said it might be an anti lock issue somewhere. The pedal is totally stiff so I removed the master cylinder and alot of psi blew out ( just air, not fluid). Then the pedal moved again, so re-installed the master cylinder and the brake pedal moves now but the brakes are still locked up. Here is the weird thing ( I have the front end up on jack stands) I put the car in gear and just slightly put my foot on the brake pedal and the wheels move, but when I apply preasure or let off the pedal they lock up again!!
Any help anyone can give me will be very very much appreciated.
You may have trash in the brake lines. Bleed all 4 wheels and be sure you have fluid everywhere.
If booster push rod is too long, it will not release the brakes and lockup will occur as fluid warms. Adjustment is a royal PIA. I bought OEM MC to avoid this problem.
Check Online Manuals links in DiY forum for a 1991 Accord download manual w/ pushrod adjustment procedure.
That's NOT the screw on the master cylinder.
Pushrod adjustment is probably down under the dash - somewhere on the pushrod from the pedal into the firewall & booster.
I think it might be the nut #17 in this picture??
alphaney
02-12-2022 10:14 AM
thunder_x
09-27-2006 11:00 PM
