92 accor wont go in 1st 3rd or 5th
ok i have a 1992 accord with a f22 and it will not go into 1st 3rd or 5th gear i have tryed to get it in but there is no grinding or anything i need some help i cant figure it out lemme know if u have any idea what is going on
it goes perfectly fine into 2nd a 4th but idk what happen help me out
RE: 92 accor wont go in 1st 3rd or 5th
have you checked to make sure there is nothing blocking the linkages from going forward?
1,3 and 5 are all the forward pushing gears. You can see all the linkages on the trans, you could
disconnect them from the stick and try and push them in manually to make sure it's a linkage problem
and not a trans problem.
