97 F22 Into 93?
you need obd2 to bod1 conversion harness. obd1 ecu that matches the 97 engine. If it's a f22b1 get the obd ecu for a f22b1 and same goes if it's a f22b2 engine.
Then if it's a f22b1 engine you will need to wire vtec since cb7's didn't come with f22b1. Other than that it should be pretty straight forward swap. Mounts are the same
AbaZ
18
07-16-2008 10:23 PM
