99 accord 2.3 vtec SWAP....EXPERTS.....PLEASE HELP!!!!!!!!
Old 03-15-2012 | 10:54 PM
krisdog's Avatar
Default 99 accord 2.3 vtec SWAP....EXPERTS.....PLEASE HELP!!!!!!!!
I have a 99 accord ex 2.3l vtec 5 speed. 2 cylinders shot craps today due to worn rings. Has 251,000 miles but body and int. are perfect. So I'm fixing her.
I found a 2.3l vtec out of a 99 accord with 118,000 miles from local salvage yard that only deals with insurance totals. Cost 400+ tax (place has good rep)
Questions;
1. Does it matter if the salvage motor was a AOD?
2. the 6th number in my v.i.n. matches totaled accord.
3. Is there any particulars I need to focus on to ensure a perfect swap.
4. I hear people referring to their vtec as "F23A1" how do I know which I have?
5. Can I tell from a pulled motor that it is a match?
Let me know what info you guys need to help me make this successful. I will have replies forwarded to my phone
I apologize if this is in the wrong section, I'm new to the site. I want to Thank You in advance for any and all help!!!!!!!!!!
Old 03-16-2012 | 12:38 PM
1. ??? What's "AOD"? Automatic vs. manual transmission doesn't matter. If you wanted to use the automatic transmission, then you should get the ECU from that donor car.
2. Good.
3. (see #4)
4. Engine type is stamped on the front of the block, alongside the exhaust manifold, right up against the split line between engine & transmission. Flat surface with stamped serial number. First line should say F23A1 in both cases. Even better if the 1st digit in the second line (block serial #) matches.
F23A1 = VTEC
F23A4 = ULEV VTEC - California car has a whole different wiring harness, so post back.
F23A5 = non-VTEC, for example from an Accord DX
5. (see #4)
99accordf23a5
05-06-2014 01:51 AM
derhntr76
02-21-2010 06:58 PM
Smudge
07-16-2009 07:21 AM
portdave
10-19-2007 10:10 AM
JohnnyWadd
02-09-2006 07:12 PM
