Apexi AFC NEO
RE: Apexi AFC NEO
AFC = Air Fuel Controller is modify an existing signal at certain rpm levels to lean out or richen the fuel mixture, ie to help produce the ideal combustion to create the most hp and at times improve fuel efficiency. But it is something that requires tuning to get the most out of and unless you’re running with a lot more then what you’ve changed on the car, it won’t help you much.
Having Apexi AFC NEO as a subject without doing a little research on what it is seems kind of counter productive. Don’t you think you should find out what something is before you ask if it will help?
