beginning of h22a build.
darton mid sleeve eagle rods an mahle pistons.the head is good but the block needs work.i found the sleeve for for 635 and the piston/rod set for 830.the only problem is its from ebay stores...what to do?????
yea no turbo all motor high compression pistons on a stock bore i called the shop i take my car to today an they will sleeve my block for a few hundred.im hoping after sleeve cost an labor i would be just under 1000$.then there is the cost of the pistons/rods an hopefully the crank shaft dsnt need to be spun or replaced
You don't have to sleeve the block if you run the Mahle Gold Series pistons you can get high c/r pistons for your n/a build. They are designed to run with stock sleeves. They run about $500 for the set check ebay.
