Boring
"punching" out a Honda isn't like an old SB Chevy....not where you want to spend your time.
I think the limit on the stock sleeves is like .02, too lazy to look. Some shops might go more.
If you are trying to do a build. I suggest you figure out what you want as the end goal. That will get you to a round about budget......if the budget fits then begin the plan....if the budget does not fit, adjust the end results, re-budget and go from there.
Is this an OBD-I or OBD-II car, then what are the state laws on testing/inspection? Again this simple question might play into your plans.
