cam gears?
RE: cam gears?
you have a SOHC unless you did an engine swap to a h22/23 or f22b, but either way, unless you are going to meet a certain engine bay style an adjustable cam gear wont offer you too much in the performance area, about all it will do is shift your power band i cant remember which is which but basically advancing it will slightly increase your off the line but it will take away from your top end, and retarding it will decrease your off the line and increase your top end
