Car dead
Old 02-03-2008 | 04:31 PM
vi3tboi
Default Car dead
I have a 2004 honda accord v6. The car has no electric inside. Nothing works inside and the car would not start now. When you turn the key, there is dead silent. Use the voltage meter for battery, battery fuse and check the furse inside the car and it looks good. What else can be the problem? The car was parked and went to friend house and it would not start again.
Old 02-03-2008 | 04:59 PM
nafango2's Avatar
Default RE: Car dead
sounds like the ignition switch to me.
Old 02-03-2008 | 06:12 PM
vi3tboi
My friend said that to me, but i hope it not. It cost alot to replace it. How can you test if it the ignition switch? My friend said you have to open it? Can it be the ECU?
Old 02-04-2008 | 12:32 AM
19Accord97
I had that happen to me once.
All it turned out to be was the battery cable was loose. Tightened it up. Problem solved.
Let us know!
Old 02-04-2008 | 03:52 AM
vi3tboi
My friend test all the fuse inside and everything is working. I have to check some more tomorrow. IF it will not work, then take it to the shop. I will check the battery cable tomorrow again
Old 02-04-2008 | 03:51 PM
vi3tboi
My other friend found out it was ground wire, so that why it weak and cant start. He got it to started and took it to his shop. It was broken in to once, so they must have done something to that. Everything is ok now.
Lenno
01-29-2012 08:45 PM
ohill1981
06-17-2011 12:48 AM
yousef
04-22-2009 11:40 PM
Destiny851
04-28-2008 03:04 PM
EzraFitch1990
04-07-2008 05:04 PM
