Check Engine Light On
Check for exhaust leaks (can cause P0420) and perform a "shake" test on catalytic converter. If it rattles, it needs replacement.
Also check briansmobile1 videos on youtube for how to inspect catalytic converter for performance.
There are new bolt-on converters from several sources on Amazon, Ebay for reasonable prices and most folks seems pleased w/ them.
Catalytic converter, exhaust leak, o2 sensor or AF sensor, probably in that order.
The AF sensor should work correctly w/o the heater element once fully warmed so replacing AF sensor may not cure P0420, but there's a chance.
78gaw
01-20-2010 10:45 AM
ddold@gkschools.org
01-29-2008 04:35 PM
PAY1920
07-01-2007 10:58 PM
