Cylinder Head
Cylinder Head
I've got an F22B2... Could I replace mine with a H22x cylinder head? I'm not 100% sure how it works but I know the displacement must be the same. Do the number of overhead cams have to be the same... I have SOHC and the H engines are DOHC or could I in some way convert to DOHC by buying 2 camshafts and installing a H22x cylinder head?
________
Buy E Cigarette
________
Buy E Cigarette
Yes you can put on a H22x head. I don't know the details of which ones are compatible, or what all you have to do. Search for "G-series" or "G-22" because that's a common slang for that combination of F-block with H-head. Also called a frankenstein.
You'll need lots of stuff. Probably an ECU from an H-engine, some wiring harness mods, etc.
H22a all the way
Chris Jameson
02-19-2013 07:39 AM
82009_honda
11-26-2009 10:17 AM
PJ_STYLES_95AccordEx
10-24-2007 10:58 PM
Drpepper
06-04-2007 12:17 PM
