engine swap on 6th gen accord... READ ME
Old 10-11-2007 | 11:09 PM
MrGmo's Avatar
Default engine swap on 6th gen accord... READ ME
hello all, its me again, mrgmo calling all our wonderfull accord gurus... well lets get to the point...
i have been thinking my car isnt going to provide the power i deserve unless i put a turbo in it... and id rather not even go that route, but if i must i will, however i was wondering what are my options for swaping out the f23a1 and putting in something with more power... i mean it picks up ok (after 4k) but i was wondering if it was at all possible to swap that 2.3 with a dohc with a little more pep ....
any suggestions would be greatly appreciated... thanks all
Old 10-12-2007 | 09:11 AM
Thataccord's Avatar
Default RE: engine swap on 6th gen accord... READ ME
I have a 6th gen. too and I was thinkin the same thing you were. I wanted an H22A which is the stock prelude engine and puts out about 200 hp but apparently its not a drop in like the 5th gen. but I do think you can swap an F20b fine. I was gonna try finding an acura TL-S engine with 260 hp and swapping that with mine and just putting the basics on. More weight but way more power haha. Your choice though.
Old 10-12-2007 | 11:12 AM
00AccordLX5spd's Avatar
Registered User
H22 will fit but it's not as easy as on a 5th gen. F20 will fit too. There is no way that TL-S will fit without some serious and expensive modification. You might as well buy a TL-S for what you'd spend trying to put the engine in your accord.
Old 10-12-2007 | 06:47 PM
MrGmo's Avatar
wait so.... there isnt any direct drop in motor i can use???? what about putting better heads on the f23?? whats the gain on that.. and would it be worth it and reliable...
Old 10-12-2007 | 06:51 PM
MrGmo's Avatar
and whats a f20 motor??? isnt there more potential with a f23? i figure since its bigger??? help me understand pls
Old 10-13-2007 | 02:33 AM
stevent's Avatar
what 00AccordLX5spd say was that fitting a 6 cyl engine into a 4 banger will need serious work since the mounts are very different and it'll cost alot too. With all said and done, you might as well put that money forth towards the TL since it probably cost around or more than the price of the car.
But the f20 is the s2000 motor and I dont think you can put a rwd engine into a fwd engine unless serious work is done on it as well.
All engines have potential in two different areas. NA and boost.
Old 10-13-2007 | 04:03 AM
MrGmo's Avatar
i see, hmmmm interesting.....
and yes ive been thinking about the whole turbo thing... although my car has like 132k miles on it... so im kinda thinking this would rip the motor up... i just got it like 3 months ago and i dont know if its even been rebuilt or what not...
however near my house is a japanese motor import wharehouse where i bought a b16 for my civic at about 400 bucks...
in any case how easy is the h22 swap??? or what about H22 heads on a f23 ive seen threads that say this can be done to transform the f23 to a dohc.....
i found turbo kits for about 1000 bucks *T3 stage 3 kits.... that sounds reasonable... but like i said... im not exactly sure my motor would like the psi's ....i mean if i do go turbo i think id run it at the minimum psi... whatever that is....
thanks for all your future responses everyone...
Old 10-14-2007 | 02:02 AM
Registered User
ORIGINAL: stevent
I was talking about the f20B engine, not the f20C. Click: http://en.wikipedia.org/wiki/Honda_F_engine#F20B_2
Old 10-14-2007 | 02:10 AM
stevent's Avatar
^ whoops haha
Old 10-14-2007 | 02:13 AM
Registered User
Honest mistake.I should have specified. Forgot the S2000 had a F20 series engine as well. But that would be frickin sweet if you could make that work in an accord. I don't see that being possibleas you already said
Elk Hunter
10-02-2012 12:08 PM
coolcat
11-24-2008 09:39 AM
Ponyboy
06-01-2008 02:13 PM
finch13
04-15-2008 11:13 AM
bigdog1428
12-19-2006 10:07 AM
