a/f sensor 1
Old 08-02-2010 | 12:32 PM
dombek2k7's Avatar
Default a/f sensor 1
hey whats going on...
so my girlfriend has a 01 accord lx 2dr... started having issues with it idling low and almost dying when it comes to a stop(stop light or sign). brought it to a local midas, cause the check engine light came on...
2 codes came up:
1166- a/f sensor 1- heater circut malfunction
1167- a/f sensor 1 heater system malfunction
the part # i need is sg1195... some type of sensor... ( i wasnt there when she went.. i was working) "a/f" air to fuel?? but heater circut and system.. so i dont think its air to fuel...
Someone help me out on this.... guy stated the part is gonna cost like $250 so if someone can give me some more info that would be great before i call around price matching this part
Old 08-02-2010 | 01:31 PM
g22cd5's Avatar
Supper Moderator
It’s the o2 sensors that are bad. I donno how many 01 accords had tho I’m a cb7 guy. Someone else should chime in
Old 08-02-2010 | 06:04 PM
Are you in Calif? On the ULEV engine the front oxygen sensor is a wide-band type instead of the plain ordinary cheap O2 sensor.
Sensor is up front, in the exhaust manifold. Unplug it & look for the 2 same-color (black?) wires. Measure resistance between them - should be 10 to 40 ohms. If not, get a new sensor. If OK, then you get to do some electrical troubleshooting in the car's wiring.
pondrun
11-08-2021 10:40 AM
elessar78
02-04-2010 04:30 PM
dmost30
09-08-2008 01:42 AM
dmost30
09-08-2008 01:42 AM
HORSEPOWERJUNKIE2007
03-31-2008 05:53 PM
