F22 n/a build or H22 n/a build?
RE: F22 n/a build or H22 n/a build?
ORIGINAL: sir_nasty
I've read that the H22 to a B series motor is only 8 lbs but I'm fairly certain that an f22 weighs less than a B Series....
"The H22, at 385 pounds for the engine, trans and axles, will add between 45 and 65 pounds to the nose of the car, depending on what your Accord had to begin with. Unless understeer is your game, you'll want to put the nose on a diet or pick from one of the many suspension options that grace these pages to support the added weight." link: http://www.sportcompactcarweb.com/te...wap/index.html
a CF hood is about 35 lbs lighter than stock, so it almost evens out.
HondaAccordEX94
10-14-2010 03:59 AM
AbaZ
18
07-16-2008 11:23 PM
