f22a6 head
nice. Have you thought about doing something like this....
f22a6 head
f22a4 header
delta 272 regrind
h23 intake manifold
f23 block (over bore by 1mm to 87mm)
h22a pistons
h22a4 crank
h22a4 rods
you would have yourself basically a h22 block with a cammed f22a head. with all OEM parts minus the cam regrind.
f22a6 head
f22a4 header
delta 272 regrind
h23 intake manifold
h22a pistons
h22a4 crank
h22a4 rods
With the pistons and rods what kind of compression should i expect? i'm all for the crazy hybrid build, i just know that i want to boost later so ya lol.
the h23 intake bolts up to the a6 perfect right?
you would have something like 10:1 or 10:2 c/r
Something similar to the h22a1 c/r. you are just using a 2mm smaller combustion chamber volume as the f22a head as its meant for a 85mm piston not a 87mm
yes h23 intake mani bolts right up.
I have never used delta but I have heard really good things. We have a sticky in this area of the forum about delta cam shafts.
With using the h22a4 crank you will be able to rev higher than the f23 crank will. That why I said the delta 272 cam regrind and h22 crank combo.
If you use h22 or k20 pistons is going to be little tricky to turbo later on. Unless it's pretty low boosting and awesome tune. If you plan on running pump gas that is.
well i was considering running e85 for fuel (i am not sure if thats what im trying to talk about, i dosent sound right)
will i still have useable power though if i'm reving higher?
i was thinking of just putting the a6 head on my f22b1 block i have now and running the heads ecu and an h23 intake manifold, does that sound like it'd give me a little fun?
the only reason im considering this is cause other things in the car a breaking and i dont know if i'll be able to complete the build right now.
the a6 head swap with h23 intake manifold will more fun than your b1 vtec. Also snag a f22a4 header and a p12 ecu from the 4th gen prelude.
But when doing your f23 f22a combo you will need to run a chipped p06 or p75 ecu
#20
alright so i tried to match up my distributor onto the a6 head and it does not line up, i can only get it to match up to one bolt. but the a6 is an external coil, so idk what to do lol, i can tighten it down pretty good with one bolt but idk how risky this is.
also is the firing order is the same right? i got the p12 out of a prelude that was literally right next to the accord except facing the other direction. lol
i talked to a shop owner here in san antonio and i'm going to put k20 piston heads in the f23 block, the c/r would be really high lol, but with a stock head 194 whp is what the engine in an integra dc was pushing.
do you have a youtube account under the same name because i think i saw you comment on a vid with a 92 accord swapped f22b1
