f22a6 head
#21
so your dizzy bolt pattern is not like this?
...o
o....o (never mind the periods I could not get the "o" to line up otherwise)
That so weird I have swapped several f22b1 dizzys on f22a heads. My f22a right now has a f22b1 dizzy on it. My cb7 was external coil and the f22b1 was internal. So I swapped to internal coil set up (very easy) when my coil pack went bad.
...o
#23
so i put the a6 head and h23 manifold on today, got every thing plugged in, had to get diffeernt injectors and fuel rail.
but after i torqued everything and put the p12 in i turn the ignition and there no cel to indicate the fuel pump turning on, i checked and you, not a drop of fuel is coming out, the car didnt have the problem previously. idk what it is, do you know what could be the problem?
