f22b2 bent rod.. next step
Old 03-10-2013 | 10:45 AM
christopherlee's Avatar
Default f22b2 bent rod.. next step
so i have a bent rod and was planning on doing a h22 swap
but sadly im only 900$ cash in pocket and the junk yards currently dont have one.
i want to run vtec but i also have to remember my budget
any ideas or helpful tips?
js, im in missouri and doing all the labor myself.
would a f23a1 head swap work? just to get it running till i can afford a whole swap?
Old 03-10-2013 | 01:44 PM
Did you move?.....your IP address is CA?
Anyway, try "car-part dot com" and search for engines in your area. Just remember are some things you'll want/need to replace during the swap.....so if you can get an engine in the four to five range,,,,the rest will go for those - timing belt, wp, rear main, misc hoses, fluids, ect....
Old 03-11-2013 | 03:18 PM
hondacars94's Avatar
swapping heads would get you by for time being, but make sure u get everything from donor car that you would need, power you want still wouldnt be there like the h22
Old 03-12-2013 | 06:02 PM
Ah, just me but if a connecting rod is bent.....a head swap is not going to do anything for the OP? Or were you going somewhere else?
Will_V
03-05-2020 11:55 PM
Restless
06-04-2013 12:09 PM
g22cd5
09-27-2011 08:57 AM
maro
08-01-2008 10:06 AM
Quick Reply: f22b2 bent rod.. next step
