F23 block with H series head and tranny?
Old 09-28-2009 | 04:56 PM
92accord808's Avatar
Default F23 block with H series head and tranny?
i have a f23A4 engine and i dont know what to do with it?
can i put a H22/23 head and tranny?
any suggestions?
Old 09-28-2009 | 08:07 PM
KevinAccord's Avatar
yes you can... not easy... it's called a G23 Frankenstein. gives around 167hp at the wheel (may be wrong). It's an awesome mod to do, and a very good one to turbo later on, since the F23 block is cast iron and the H22/23 head it pretty much awesome. the tranny will be around 90% compatible, and unless you're very skilled mechanic i would recommend to send it to an expert.
Old 09-28-2009 | 08:09 PM
almost forgot, it will be around 3k...
Old 09-29-2009 | 12:42 AM
h22a96_Accord
You may be better off saving up for a complete h22a swap bro. They are the best bang for your buck, and there are certain complications that will come with any Frankenstein build. It will cost about 1-2k more though depending where you live and who you know :P
Old 10-01-2009 | 09:57 AM
true... i only said 3k in parts...add labor and it will be 1-2k more....
Old 10-01-2009 | 10:29 AM
Lightbulb Info For You Also
I suggest you read the post sbove yours about the I wat my 97 to get 200HP..
Same info applys to your wants:
HondaAccordEX94
04-27-2010 09:45 PM
g22cd5
07-30-2009 08:15 PM
BuntinBoy9
11-11-2007 07:56 PM
vtechex
07-27-2007 08:57 AM
silverbullet2006
07-01-2006 06:04 PM
