Finally want to repair my 95 Accord
Old 04-20-2006 | 09:11 PM
tunedis95
Default Finally want to repair my 95 Accord
well i've been putting this problem off for a while
Problem: After my 95 accord (automatic) warms up and driving about it acts fine. but when i stop at a light, the car beging to stall out and will do so in about a second or two from when the rpm start to drop from 800rpm till it dies and i have to throw in in neutral and start it up again. also my rpm guage works but my speedo does not work and my D1 light blinks all the time.
What i've been doing about it: When ever i stop at a light i pop it in neutral till the light turns green and drive off like normal
Problem started when: my second transmission went out on the car so i went ahead and replaced it and this is when it started. So this is my only problem. the transmission works great other than that.
PLEASE HELP >>>>>THANX >>>>>>ERIC
Old 04-20-2006 | 09:32 PM
sir_nasty's Avatar
Default RE: Finally want to repair my 95 Accord
is there a pattern to the light? I.E. 4 blinks, long pause 2 blinks, short pause (repeat)? My guess would be one of your transmission sensors... did you connect the throttle cable to your tranny? Look in there for anything that's not connected and let us know...
Old 04-20-2006 | 10:01 PM
tunedis95
everything looks connected from what i can see....been under there a few times and look on top on side and all that good stuff......its a steady blink....half second on half second off.......consistant
Old 04-21-2006 | 12:25 AM
AgentofDarkness's Avatar
Check the fluid level, that problem can be caused by low fluid in some transmissions.
Old 04-21-2006 | 12:55 PM
tunedis95
Default .....
i'll check that today.........anything else ya......
Old 04-22-2006 | 02:14 AM
lightshow's Avatar
Default RE: .....
your broken VSS has to be making most of the problems your experiencing. maybe that and a little twist counterclockwise on the screw thats on top of the throttle body and your days of needing to put it in neutral will be over.
Old 04-22-2006 | 09:43 PM
tunedis95
Default RE: .....
ok....so i've narrowed it down to the vss i guess.....ok.....i have a 95 honda accord with its stock 95 engine.....and the trans i'm not sure what year it came off of. how can i tell what year its from if it matters and what year vss do i need
frezel
05-14-2011 09:11 PM
stokins316
01-25-2011 08:04 PM
02Hawkord
02-21-2008 11:57 AM
GirlyAccord
02-19-2008 11:22 AM
gookie monster
02-22-2006 11:59 PM
