Fuel Additives
Old 11-03-2006 | 02:10 PM
marbro's Avatar
Default RE: Fuel Additives
yeeeeah, thats why i use optima yellow top...... you dont have to deal with any of that.... whats that? completely drained your battery and your worried it wont work anymore? recharge it...... guess what.... it will
i use lucas fuel injector cleaner i havent had any problems with it, in my old saturn i use to use rubbing alc, but no one sells the type that i used anymore
Old 11-03-2006 | 04:27 PM
sir_nasty's Avatar
funny you should mention rubbing alcohol.... my friend used to buy just the store bought 100% rubbing alcohol and add it to his fuel at each fill up... it actually gave him a little better throttle response but there's no telling what it did to his vehicle.... quite amusing really...
Old 11-03-2006 | 06:12 PM
abhijitgp's Avatar
So what is the conclusion of this discussion? The baking soda paste is useless..... and for fuel injector cleaner, I should use branded stuff... what about STP fuel injector cleaner? My car has gas tank of 21 gallons and it is almost empty now... should I just put one bottle of it and then fill the tank with gas? Is there anything else I can add that might clean the engine cylinders as well? I dont think I am much confrotable using seafoam in vac line and other places mentioned before. But putting 1/3rd bottle of seafoam just in the gas tank will work or do I have to put it in other 2 places mentioend too ??
Thanks
Old 11-03-2006 | 06:21 PM
abhijitgp's Avatar
Also, I have a newbie question... where are these brake vac line and crankcase located?
Old 11-03-2006 | 07:12 PM
vintageant's Avatar
Do a search for other threads with Seafoam. OK to use in vac line as directed. Only difference I would add is leave it for 30 minutes to really soak into the carbon and crud. When you start it, don't let it idle! Get going and drive a steady 3000 RPM for about 3 miles. That's how long it will smoke for, and you'll want to have the car moving so as not to upset your neighbors.
Old 11-06-2006 | 12:58 PM
abhijitgp's Avatar
Thanks a lot
  #17
Old 11-10-2006 | 05:37 PM
abhijitgp's Avatar
Sorry for posting again on this topic, but no one replied when I posted this conclusion last time.. I just wanted to double-check !
what about STP fuel injector cleaner? I just bought one bottle of concentrated one of it. My car has gas tank of 21 gallons and it is almost empty now... should I just put one bottle of it and then fill the tank with gas? Is there anything else I can add that might clean the engine cylinders as well? I dont think I am much confrotable using seafoam in vac line and other places mentioned before. But putting 1/3rd bottle of seafoam just in the gas tank will work or do I have to put it in other 2 places mentioend too ??
Thanks a lot
  #18
Old 12-15-2006 | 03:12 PM
91boz's Avatar
Get yourself a can of BG44K power enhancer. The best stuff out there to clean the fuel line and injectors. It also removes the carbon and cleans the upper cylinder and valves. Most car dealer service department stocks this stuff or you can find it on Ebay. Believe me there is nothing better out there just add to gas.
  #19
Old 06-22-2012 | 12:43 AM
mbrain's Avatar
Default Marine stable
CAn I use marine stable in my tank to help mitigate the damage from ethanol?1993 Accord.
  #20
Old 06-26-2012 | 05:44 PM
What's "marine stable"? You mean a marine version of StaBil? I think it's not really a "cleaner" but rather it prevents gasoline from becoming "stale".
What exactly is damaged from ethanol? It's got less energy than pure gasoline, but not really dirty-burning.
phatboyslim2012
03-21-2012 09:14 AM
dirtMccord
03-01-2007 12:01 AM
igot2gonow
02-18-2007 03:18 AM
blackpearlv6
07-24-2006 01:03 PM
FlyLow
12-04-2005 11:45 PM
