H22 Head to h23 block
Old 09-23-2009 | 06:58 PM
JDMH23lngBlk
Lightbulb H22 Head to h23 block
Hey everyone... im currently building a h23 motor to put into my 95 accord coupe. I would really like to do an h22 head though so i can incoorperate the vtech on the motor. 1 does anyone know where i can find an h22 head and does any one know what kind of work and money im looking at..
Old 09-24-2009 | 09:50 AM
I think this will do better in the Engine/Internal section, so I'll move it. The DIY section isn't really for questions, it's for long detailed procedure write-ups.
Old 09-24-2009 | 01:19 PM
botang47's Avatar
h22a head
h22a power steering braket
h22a thermostat housing
h22a water pipe
h22a water pump
h22a lower crank gear
h22a head gasket
h22a plug wires
h22a timing belt
h22a head bolts
h22a header and downpipe
h22a intake manifold
h22a top timing belt covers
h22a cam gears
you need to remove the oil control plug in the block before putting the head on.
you will need to run wires and the ecu, for the vtec solenoid and knock sensor
80s-tuner
09-10-2010 05:27 PM
abr0s
10-03-2009 04:31 PM
gosu08
01-24-2008 08:04 PM
1993accordSE
04-15-2005 12:30 PM
1993accordSE
04-01-2005 10:41 PM
